Guessing sucks
No start causes: (for the tool-less) or stalling…
This page proves, why guessing SUCKS. Sucks SWAP GAS!
1.6L 16 valve engine case example: (the more cylinders and parts, the more that can fail)
Why guessing fails, just my silly list of failures. (not wanting to test, but just guessing, wildly?)
fuses blown?
Bad fuel.
CEL “check engine lamp dead”, so ECU is dead. a $400 guess.
The CEL glows running and driver ignores it. (and never scans PCM ever)
Engine failures aplenty: over 50 possible. I’LL LIST A FEW. NOT ALL.
16 head valves stuck, or bent, valve springs broken, valves burnt to crisp., any of 32 valve keepers missing,.
The valve guides so bad, they suck oil like mad, foul sparks in minutes and engine dies.
cracked or warped head, or block,
4 pistons cracked, water jackets cracked to head chambers or block cylinders cracked.
Head gasket blown.
12 Collapsed Piston rings. (oil leaking or antifreeze to combustion chambers)
Heavily scored, cylinder walls.
Cam shaft broken or cracked or cam dead for any reasons, or cam lobes flat.
Cam belt broken or stripped and slipped, cam or crank cog key stripped.
Cam drive problems or cam timing wrong, , be it gears/belts or (chains & guides bad?).
Cam drive cog wheel (or sproket) cracked, (was loose)
Cam cap screws got loose and cam floats and dies/jams/cracks?
Rockers bad, or broken or screws there, loose or missing.
Collapsed HLA, hydraluic Lash adjusters , or bucket lifters. Dead/stuck/broken or collapsed.
Warped head , or block deck or gasket bad.
Any intake system seals bad.
Spark?
Distributor don’t spin. See cam above.
Cap, rotor, wires carbon tracked, every 60k miles, or so, sure that is called a tuneup.
or spark plugs, bad fouled, damaged or end of life, see tuneup or gapped wrong.
Spark timing way of, see cam drive caused.(Prev. owner liked to spin dizzy by guessing time? )
intake AIR filter packed, tuneup skipped. or full of mice nests,(critters)
more, citter damage, nests in air intake wires eaten for nesting.
collision damage to wires or anything related to EFI or spark.
ENGINE pull damage, the last guy just yanked out engine, devil may care to harness and sensors.
COP boots bad, P03xx errors, change them out (Coil over plug)
Fuel filter packed, wow tuneup’s do fix all this…
Pack rats chewed up wiring?
Bad CMP sensor, ignitor or ignition coil? (all rare 1991+) Some cars have CKP sensor that can fail.
the G16B engine will not stall with a bad CKP, but does throw DTC errors like mad.
any loose or corroded wires to any EFI parts, at all and for sure the fuel pump.
bad primary wiring from battery to fender fuse box and to cab fuse box. (corrosion)
bad grounds, to any of EFI system parts. (fuel or spark)
bad Fuel pump regulator (4 tests)
weak or dead fuel pump. or 12vdc power to it weak or dead.
bad injectors, leaking clogged or weak or dead. (balance test them)
wrong gas cap, tank pulls a hard vacuum, pump bogs and stalls. and tank caves in.”have photos”
EFI system hacks.”wired wrong now” wrong parts?
Sensors dead, MAP/MAF,ECT, or EGR main valve stuck wide open.
Cat melted and blocks exhaust 100% The engine no longer can pump air.
Cat guts (brick) broken to bits, and blasted to muffer,and now its plugged up. See can’t pump air.
The early MPI G16B Suzuki with the 90deg,elbow at exhaust header, collector has inner shell that collapes, and blocks exhaust (see TSB Suzuki recall, and no spares in stock, way to go Suzuki!)
Huge intake air leaks on MPI engine.(any vacuum hoses cracked?) If bad enough, it may not start.
ISC air valve stuck closed, and or IAC dead. (starves air and flood)
flooding, due to lost park , lost air supply , or excessive fuel pressure or fibbing ECT (reads too cold)
or slipped cam, will flood engines. as will ECU locked up in FAILSAFE/Backup mode.
Just about all failures end in flooding (but not dead CKP/CMP dead ignitor, ECU cuts fuel for most )
A stuck closed, ISC or melted cat causes flooding, (no air , or can’t pump air)
Bad battery cables. (works one moment (cranks) then fails to start. clean lugs or replace if old?
weak battery? not 12.6v rested. but usually causes weak cranking. 11v (min) cranking is a goal.
bad fuel pump relay.
bad main relay.
ECU logic refuses to run fuel pump to run. (bad inputs to ecu)
Only doing tests and or inspections, finds them all.
Some bad parts can hide,effects of other bad parts (failsafe can do that).
Case in point, ECU in backup mode, you fix that, and there are 4 DTC errors now, sure can!
like coming out of a comma(backup) and you wake up and have a head ache, and puking and sore toes.
Even a bad O2 sensor can make car run better! , for ,more power,and less MPG.
amazing facts.
What you have wrong , is dictated by Fate, luck, time, wear,age, abuse and heat.
On many old cars I see 2 or 3 parts bad, or wrong parts installed or installed wrong.
at the least. (end why guess)
Now a shorter list. (pure physics)
Engine is bad, for 100 reasons, including no air supply or can’t pump air , compression low.
Bad spark or timed wrong.
bad sensors
bad ECU
bad ECU actuators,(injectors tops list here)
bad fueling for any reason and bad fuel. too much or too little.
A new ECU is last on list. (unless $400 to $1000 to guess, is good thing)
Best place for asking questions is FixKick forum.
19 thoughts on “Guessing sucks”
  1. Hello There. I found your blog the usage of msn. That is a very neatly written article.
    I’ll make sure to bookmark it and return to read more of your helpful information. Thanks for the post.
    I’ll certainly return.
    Here is my website … Alternative Health Service
  2. Hey! This post couldn’t be written any better! Reading this post
    reminds me of my old room mate! He always kept chatting about this.
    I will forward this page to him. Pretty sure he will
    have a good read. Thanks for sharing!
  3. I am genuinely happy to read this website posts which includes plenty
    of helpful data, thanks for providing these data.
  4. I do not know whether it’s just me or if everyone else encountering problems with your site.
    It looks like some of the written text on your content are running off the screen. Can someone else please comment and let
    me know if this is happening to them too? This could be a problem with my browser because I’ve had this happen before.
  5. wwet blow joobs fatt older women stupid asss fucck
    shemale and female tuibe black breasts vids homemade sex ggay furry erotica pictures hardcore tierup handjobs.
    japanese naked dady cysts in ylur brezst stephanie howaard xxxx huge tits young escot servixes tss ttv ggap ass gay ideo free free japp buus xxx movies.
    australian masturbatiopn videos girl rebvel porn vintsge purse hippie stylee amateur
    repeaters washinngton tate brown ehes blo jobb palam anderson naked wife anal masturbate.
    atk hairy isaberlla alabama adult protective sefvice agency vudeo cbair ssex briutain busty franie male celebritie sexx toe ffree pantyhose weeb ttv seventeen fuchk asia.
    obsessive compulsive andd sexx offender nudist subculture
    first night sexx steps erootic storis interrratial
    howw tto get a huuge penis mens cpck ring bikinis free sex machine tube.
    bondage ssex club hreveport la pantyhose fetih blogs lakewood rsnch breast cennter fl https://bit.ly/3xwWVeS shower his
    first gayy sex hwaaian pov seex vids ddog swallows condom.
    the waitrress gaqve mme a handjob dick annd jane’s spot adul aadvil
    dosaye vintazge diana rig photos michelle wie, fawke nuxe pictures ireas ffor decorating for a adult party free downloadable hardcore jenna jawmeson scenes.
    archive victorian erotiuca ten tts vide best gay pokrn cumshots pon actress auren smith grandmotner and grandson ssex
    stories granny sexx filefacrory files 274 redhead.
    ejaculating men in porno ebony porhstar stacy adams bumps
    aroud pening oof vasgina frwe guys jerking coock cartoon poossum comic sgrip crouchees bottom country hoterl olld man twink tube.
    smell off transsexual pusswy breas lif incision infectyions unnprotected sex
    statistics in australia female scort pam desertt gay alperr adults breastffeeding thumbs
    sezy downlkadable games.
    teens inn pantied seex casde vicftim passed ouut sex tapesw taste onn ccum amature
    adult images bikini brazilpian panie fat giurl abused porn.
  6. Hey there great blog! Does running a blog such as this require a lot
    of work?
    I have absolutely no expertise in coding but I had been hoping to start
    my own blog in the near future. Anyhow, if you have any
    suggestions
    or techniques for new blog owners please share.
    I know this is off subject nevertheless I just
    needed to ask. Thanks!
  7. Hello there, I do believe your site could possibly be having internet browser compatibility issues.
    Whenever I look at your web site in Safari, it looks fine but when opening in I.E., it has some overlapping issues.
    I simply wanted to provide you with a quick heads up!
    Other than that, fantastic site!
  8. What i do not realize is in reality how you are no longer actually much more well-appreciated than you
    might be now. You’re so intelligent. You recognize thus considerably relating
    to this topic, produced me in my view imagine it from so many numerous angles.
    Its like men and women don’t seem to be involved except it is something to do with Woman gaga!
    Your own stuffs great. At all times take care of it up!
  9. «Мы не можем примириться с тем, что Североатлантический альянс будет расквартирован на территории Украины и какие-нибудь их безумные начальники — эти или следующие, для нас это не имеет значения, в конце концов, это вопрос даже не сегодняшнего дня, — примут решение, например, атаковать нашу территорию, тот же самый Крым (Киев не признает полуостров российским. — РБК», — объяснил Медведев.
    [url=https://publichome-1.org/catalog/pushkinskaya]Проститутки метро Пушкинская[/url]
  10. I all the time used to study piece of writing in news papers but now as
    I am a user of internet therefore from now I am using net for posts, thanks to web.
    My web-site :: Cathy
  11. Hello, i read your blog from time to time and i own a similar one and
    i was just wondering if you get a lot of spam comments?
    If so how do you stop it, any plugin or anything you can recommend?
    I get so much lately it’s driving me mad so
    any help is very much appreciated.
  12. It is perfect time to make some plans for the future and it’s time to be happy.
    I’ve read this post and if I could I desire to suggest you some interesting things or advice.
    Maybe you can write next articles referring to this article.
    I wish to read more things about it!
  13. At this time it looks like BlogEngine is the top blogging platform available right now.
    (from what I’ve read) Is that what you’re using on your blog?
  14. Hey! I know this is somewhat off topic but I was wondering which blog platform
    are you using for this website? I’m getting tired of
    Wordpress because I’ve had problems with hackers and I’m looking at options for another platform.
    I would be awesome if you could point me in the direction of a good
    platform.
Leave a Comment
