1994 Sidekick 16v AT 4x4 4dr virgin ECM Ruby's still there - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 1994 Sidekick 16v AT 4x4 4dr virgin ECM Ruby's still there (/thread-1994-sidekick-16v-at-4x4-4dr-virgin-ecm-ruby-s-still-there) |
RE: 1994 Sidekick 16v AT 4x4 4dr virgin ECM Ruby's still there - fixkick - 11-14-2020 (11-14-2020, 07:49 AM)SidekickTripper Wrote: Update:all; looks good. "I disconnected the vacuum hose from purge solenoid causing a vacuum leak and the HO2 sensor went to varing mv about 10mv to 900mv . The Injector pulse width drop to about 3 ms +or - Lean Rich status fluctuating between both." a great test. so the air leak dropped it to 3mS. proving the O2 wakes up and that ECU is setting rich condition, and is some input to ECU is wrong, and sure MAF is one, cause. so adding un-metered air causes O2 to wake up. I agree,. check maf carefully, for correct voltage on output pin key on nostart, then idle and then gunned. and trick below ( a crude dyno) you have 4speed A/T so use it as a dyno for maf readings, use AT for load, (in drive, voltmeter to Maf output at idel then hand brake on , choked wheels and foot on the brake pedal, (safe) now stop the throttle hard, 3 seconds max. see if you can get 3 volts or more. same test as A/T stall test. the clutch will limit RPM to 1500 to 2000 RPM in gear. this puts a huge load no engine. for short time. (short time to not overheat clutch) maybe the MAF is offset high?, a rare event, but anything is possible on hot wire MAF. try to find tag on MAF that shows this 58B00 ( I ask this because clones do not have this number) USA pn. 1992 to 98 13800-58B00 good luck to you !!! RE: 1994 Sidekick 16v AT 4x4 4dr virgin ECM Ruby's still there - fixkick - 11-14-2020 MAF (Brand Most Plus Part number M3389 102015) last number is date sure. what in the world is this. ? ahh that is a cloned maf from china, the $22 buck maf. 400 is par par, try a MAF from USA rebuilder famous, CARDONE. or Spectra premium, (maker of fuel tanks, USA prime) and this. even $17 sensors on amazon and 25 more.. all dirt cheap from China. many will run on engine, but not right. not hold closed loop. https://www.amazon.com/Cardone-74-10033-Remanufactured-Airflow-Sensor/dp/B000C49G3G/ref=sr_1_24?_encoding=UTF8&dchild=1&qid=1605309963&s=automotive&sr=1-24&vehicle=1994-1-5------------1&vehicleName=1994+Suzuki+Sidekick delco or beck, Delphi. most seen here are good all are top brands, but WVE https://www.rockauto.com/en/catalog/suzuki,1994,sidekick,1.6l+l4,1271427,exhaust+&+emission,mass+air+flow+sensor,5128 RE: 1994 Sidekick 16v AT 4x4 4dr virgin ECM Ruby's still there - fixkick - 11-14-2020 the ecu has table inside that correct the non linear nature of the 58B00 MAF and if not same , I can imagine the ECU going nuts. The table takes log curve actual and converts it to linear, FLOW. so the math to inject is simple I have no faith in any china no name brands a new one was sent to me to test, DOA in shop opened it up and the PCB inside was wired backwards. I reversed engineered a schematic for fun, (insomnia) here it is failing https://fixkick.com/sensors/china-maf/cloned-maf.html RE: 1994 Sidekick 16v AT 4x4 4dr virgin ECM Ruby's still there - SidekickTripper - 11-20-2020 Hi Fixkick. My troubles are over!!!! I cann't believe that the poor quality MAF sensor was reading correctly, but was sending bad information to ECM. Intalled New Cardone MAF sensor 74-10033 At Idle now : Rich Lean status fluctuating Rich/Lean IAC 10 L/Min Inj Pulse dropped to 3.2 ms STFT 128 LTFT 125 HO2S Activated 801mv fluctuating TPS .86 volts Trottle angle .0 degrees Engine Coolant Verified by Infared 181F and 317 OHMs And the best part it PASSED SMOG ! 15mph HC 25 ppm CO% 0.03 NOX 289 ppm 25mph HC 8 ppm CO% 0.08 NOX 105 ppm Thanks so much. I thought I was going crazy. Experience again prevails! RE: 1994 Sidekick 16v AT 4x4 4dr virgin ECM Ruby's still there - fixkick - 11-20-2020 wow that is sooooo good to see. CURED, SOLVED the problem is worse now, I see like 20 fake makers of MAF there, not good. even $17 MAF, thanks for the 3.2mS data point !!! USEFUL that. Happy Thanks Giving to you and all your family. (revised MPI page PWM) |
