91 8V hard start long cranking on hot soak. cold great - Printable Version +- Car Repair Forum (https://fixkick.com/forum) +-- Forum: Suzuki (https://fixkick.com/forum/forum-suzuki) +--- Forum: Sidekick/Tracker (https://fixkick.com/forum/forum-sidekick-tracker) +--- Thread: 91 8V hard start long cranking on hot soak. cold great (/thread-91-8v-hard-start-long-cranking-on-hot-soak-cold-great) |
RE: 91 8V hard start long cranking on hot soak. cold great - fixkick - 12-22-2014 great ! the FPreg leaking gas to top of TB , ouch (acting and an illegal fuel injector, OMG that is evil) and the TV butterfly plate leaking air. the very high mileage , tv might wear the shaft bushings and then cause tv To bore wear. all you can do, is get the valve to close fully but not actually touch. then get the bleed set to 50% duty cycle. but now all is well happy holidays to you and all friends and family. RE: 91 8V hard start long cranking on hot soak. cold great - barnbiketom - 12-23-2014 drove today.. idles 800-900 i think i will leave it alone haha was going to ask how to CALIBRATE or SET the thermal since I turned the adjuster.. but seems ok??? now on to BALL JONTS .. rock auto here I come!!!! RE: 91 8V hard start long cranking on hot soak. cold great - fixkick - 12-23-2014 it not mess with it. the isc dont need to be at 50% duty cycle. to work right. ( |
